XFX 6850 Low FPS?
grxog
31
Good evening everybody,
Yesterday I installed a ATI Radeon 6850 by XFX. I installed it and got the drivers with no problem. Now, my games run a little faster then my MSI 4350.. I have both pci power connectors in the card, latest drivers, I tried older drivers too. GTA IV bench mark was at 21 fps. Counter strike global offensive runs at the same speed as before.
I have a 650watt psu
6 core 1045t at 800MHz, i turned off powernow. (This cpu is supposed to be at 2.7ghz a core at its lowest so if anyone knows the problem for this please let me know.)
And I still get very low fps.
please help
~GrXoG
as a side note, using gta 4 is a bad indication of gamign performance, as its scaling from card to card is pretty terrible. It can still run bad on high end setups. Global offensive though would be irregular. what drivers are you currently using.
