T Thomas8838 Reputable Mar 28, 2014 4 0 4,510 Mar 28, 2014 #1 So the card I have is an xfx 7870 dd black edition and the fans will spin for a second and then stop, then spin but they just keep stopping. Could really use some help!
Solution logang Mar 28, 2014 Bearings might be going bad in the fan https://www.youtube.com/watch?v=uqSG_I4St9Q Doesn't look like it is an uncommon problem.
logang Honorable Mar 29, 2012 503 0 11,160 Mar 28, 2014 #2 Are the rubbing against something? Do they spin freely by hand? Upvote 0 Downvote
T Thomas8838 Reputable Mar 28, 2014 4 0 4,510 Mar 28, 2014 #3 Yeah it spins freely, makes a weird noise when the fans do spin. Upvote 0 Downvote
logang Honorable Mar 29, 2012 503 0 11,160 Mar 28, 2014 #4 Makes a weird noise in that it is rubbing, or perhaps the bearings have gone bad? Upvote 1 Downvote
T Thomas8838 Reputable Mar 28, 2014 4 0 4,510 Mar 28, 2014 #5 I know for a fact that it is not rubbing anything it's just making a noise when it does spin for a split second. Upvote 0 Downvote
logang Honorable Mar 29, 2012 503 0 11,160 Mar 28, 2014 Solution #6 Bearings might be going bad in the fan https://www.youtube.com/watch?v=uqSG_I4St9Q Doesn't look like it is an uncommon problem. Upvote 0 Downvote Solution
T Thomas8838 Reputable Mar 28, 2014 4 0 4,510 Mar 28, 2014 #7 Well that sucks, looks like im gonna have to rma this piece of shit. thanks for your help. Upvote 0 Downvote
