XFX 7970 DD dual monitor problems.
curtisshim
13
Hi. I recently put an old 19 inch monitor using the DVI port with my 24 inch hdmi monitor. When i first started using it, everything was fine, but after a while my main monitor shit on me and had a bunch of lines going horizontally. I pressed my reset button and after the boot up, everything was fine. This might have been while i was using flash player but i dont know if that is the problem. My 2nd monitor was completely fine and only my main monitor had shit on me. Should I RMA or is there some sort of bug that i dont know about? Thanks ahead of time.
I have the same problem, just disable hardware acceleration in flash player. I think its just a driver glitch with the XFX cards, ever since disabling acceleration the problem stopped. Don't bother RMA'ing the card, Ive submitted the error to AMD driver department you should do the same.
