XFX PRO750W vs Corsair CX750 Builder Series.
Backtothere
305
I can't find many reviews on the Corsair so:
1. How does teh long term reliability of the Corsair compare to the XFX (I had 2 broken ones delivered to me but it has a 5 year warrenty for the ones that do work)?
2. Which makes more noise at full usage?
3. Do you reccomend trying a third XFX or getting a Corsair?
i dont have experiences wth xfx.. and ill go with corsair given it is AX series.. cx series is for entry level rig,(no OC,and 24/7 usage) but to answer your question id go for corsair.. and they have really3x good customer service
Well I don't blame you from shying away from another XFX based on your experience.
Obviously a bad manufacturing run.
For the same quality of components you would have to go above the CX series.
A TX or HX are much better then the CX.
AX are top of the line but overpriced in my opinion.
