XFX r9 270x with VGA Monitor with DVI - VGA Converter not working
Kaushik DB
7
I have
http://xfxforce.com/en-us/products/amd-radeon-r9-series/amd-radeon-r9-270x-double-dissipation-edition-r9-270x-edj4
And Bought DVI to VGA Converter
http://www.flipkart.com/jinali-dvi-male-vga-female-converter-data-cable/p/itmefahymgghrffj?pid=ACCEFAHYGQHQFBUA
But it's not working.
1. I'm not sure if both DVI on my card is DVI-I or DVI-D but they looks exactly the same. (with the pin arrangement)
2. Someone wrote that i'm supposed to use that converted with monitor not that card. I'm confused here.
My monitor only have VGA, how can I connect it with my card (i'm also running another monitor on DVI).
This model has a DVI-I and DVI-D, the DVI-I that supports analog is positioned next to the HDMI. The DVI-D which doesn't support VGA is under the HDMI.
If you need to use 2 Vga monitors, i recommend getting a DVI-VGA adapter and a Displayport to VGA adapter.
The only models we make that supports dual VGA without the use of a displayport are...
R5 220's
XFX One's
5450's
All other models require the use of displayport to get a 2nd vga.
Thank you
XFX_Support
R5 220's
XFX One's
5450's
Thank you
Kaushik DB
7
XFX_Support, are you sure? they looks exactly same though.
And I have a DVI monitor and a VGA monitor. So I tried hooking up like this
DVI (beside HDMI) > Adapter > VGA Monitor
DVI (under HDMI) > DVI Monitor.
My DVI monitor works but my VGA monitor doesn't get any signal nor the windows recognizes it.
Am I getting the Adapter wrong?
What apapter I should get. I'm in India.
Thank you.
