Well hello everybody i've Run into some problem with my brand new R9 Fury . Installation want good i've installed the brand new drivers from Crismon 16.3 i do believe, no problem at all , run some test everything was fine. no heat problem , no flickering , no nothing until i go into saphire Trixx and boost up the core to 1050mhz from 1000mhz which is nothing... then Black screen. Start back the cpu, well it want into a Reboot loop, so i removed the card run it on intel HD 4600 from the mobo no problem going into the desktop, so i deleted all Amd drivers with DDU. put the card back on Start up the cpu no problem running , install the drivers and upon installation it does it again , so i rince and wash with older driver , newer driver and everything, did a back up windows just in case. same still happening -
my setup .
-Windows 10 64-bits
-I5-4690K stock OC
-Msi Z97 Pc Mate
-Gskill Sniper 2400mhz
-Gskill 240gb SSD
-2 X 1TB WD Blue HDD
-Lepa Aqua charger 240mm Cooler and 4 x 140mm Fans in the case
-Cougar CMX 1000W
ps i was Running a Gigabyte R9 390 gaming G1 Not to long ago , perfectly fine.
my setup .
-Windows 10 64-bits
-I5-4690K stock OC
-Msi Z97 Pc Mate
-Gskill 240gb SSD
-Cougar CMX 1000W
