MorrowindExplorer Reputable Aug 10, 2014 67 0 4,640 Feb 1, 2016 #1 I need to Purchase a Corsair Case that is big enough to fit the XFX Radeon 5870. Which case would be suitable?
Solution Newbbuilder11 Feb 2, 2016 MorrowindExplorer : clarkjd : budget, please! As there are several that would fit the card. For the Case I would go as high as, 120$ card is around 280 mm in size, so these cases will do. http://www.amazon.com/Rosewill-Gaming-Tower-Computer-Challenger/dp/B00BV31QU8/ref=sr_1_23?s=pc&ie=UTF8&qid=1454428949&sr=1-23&keywords=computer+case http://www.amazon.com/Corsair-Carbide-SPEC-01-Gaming-CC-9011050-WW/dp/B00I6BJATW/ref=sr_1_5?s=pc&ie=UTF8&qid=1454428949&sr=1-5&keywords=computer+case http://www.amazon.com/Cooler-Master-HAF-912-RC-912-KKN1/dp/B003ZM7YTA/ref=sr_1_44?s=pc&ie=UTF8&qid=1454429104&sr=1-44&keywords=computer+case...
clarkjd Splendid Dec 7, 2005 6,486 34 28,490 Feb 1, 2016 #2 budget, please! As there are several that would fit the card. Upvote 0 Downvote
MorrowindExplorer Reputable Aug 10, 2014 67 0 4,640 Feb 1, 2016 #3 clarkjd : budget, please! As there are several that would fit the card. For the Case I would go as high as, 120$ Upvote 0 Downvote
clarkjd Splendid Dec 7, 2005 6,486 34 28,490 Feb 2, 2016 #4 IT would fit in any of these: http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=100007583%2050001459%20600006302%204017&IsNodeId=1&bop=And&compareItemList=7|9SIA6ZP3NH4360^9SIA6ZP3NH4360%2C9SIA6ZP3NX9321^9SIA6ZP3NX9321%2C9SIA9FT3GT2386^9SIA9FT3GT2386%2C9SIA24G2HZ2998^9SIA24G2HZ2998&percm=9SIA6ZP3NH4360%3A%24%24%24%24%24%24%24%3B9SIA6ZP3NX9321%3A%24%24%24%24%24%24%24%3B9SIA9FT3GT2386%3A%24%24%24%24%24%24%24%3B9SIA24G2HZ2998%3A%24%24%24%24%24%24%24 Sorry, link is broken.🙁 Basically, any of the Carbide or Obsidian mid tower cases would hold your card. Upvote 0 Downvote
Newbbuilder11 Honorable Feb 6, 2014 1,563 0 12,460 Feb 2, 2016 Solution #5 MorrowindExplorer : clarkjd : budget, please! As there are several that would fit the card. For the Case I would go as high as, 120$ card is around 280 mm in size, so these cases will do. http://www.amazon.com/Rosewill-Gaming-Tower-Computer-Challenger/dp/B00BV31QU8/ref=sr_1_23?s=pc&ie=UTF8&qid=1454428949&sr=1-23&keywords=computer+case http://www.amazon.com/Corsair-Carbide-SPEC-01-Gaming-CC-9011050-WW/dp/B00I6BJATW/ref=sr_1_5?s=pc&ie=UTF8&qid=1454428949&sr=1-5&keywords=computer+case http://www.amazon.com/Cooler-Master-HAF-912-RC-912-KKN1/dp/B003ZM7YTA/ref=sr_1_44?s=pc&ie=UTF8&qid=1454429104&sr=1-44&keywords=computer+case http://www.amazon.com/VIVO-Computer-Gaming-Desktop-CASE-V03/dp/B011C5M6KI/ref=sr_1_52?s=pc&ie=UTF8&qid=1454429156&sr=1-52&keywords=computer+case choose one Upvote 0 Downvote Solution
