XFX Radeon HD 7850 Dual Monitor Issue "No Signal"!
seelroy
For the past several hours I've been trying to figure out why I can't get a second TV to work. It works perfectly fine with HDMI, however when I chose to use VGA with a VGA-DVI converter it does not work. The display is detected as VGA, so it knows it's there, however there is a "No Signal" being displayed on the TV. I can't even get it to work on the main TV I use, which is of the same make and model. I've even tried booting with just it connected, and nothing. I've also re-installed the graphics drivers, only thing that changed was I got VGA settings to pop-up in CCC.
Previously I had a Radeon HD 5750 that was running both of TVs perfectly fine, I switch it out for the XFX Radeon HD 7850, and it doesn't work. I wasn't bothered by this change of events, I just defaulted to using one, but I'd like to use a second monitor again. Any ideas on how I can resolve my issue? Thanks :)
Not a very techy person when it comes to Hardware so I'll post screenshots below!
Screenshots of my specs:
Similar threads
