XFX Radeon R7 370 DirectX 12 R7-370P-2255 2GB 256-Bit GDDR5 PCI Express 3.0
Nghtrider62
4
I Built this system almost 5 years ago From A Settlement, With the ability and plans to Upgrade as I go along and as $$$ allowed.
In November My 6770 Video card Fan blades exploded there was 5 blades left on it of 11, I pulled the fan and was using a 80mm case fan zip tied to the frame of the 6770 video card until I was able to replace the card.
In Mid December I replaced it with this XFX and since I have been playing, My frame rates Are way below What I expected this card to be able to do., I have a open ticket Since Dec. With XFX support. I bought on Newegg new.
I have Windows Video Hardware Error messages,
The Solution Applies to these Problems: Solution: Solve a Problem with AMD/ATI Video Driver
Windows Video Hardware Error Solution Available
Shows 10 different times when the Video Card Drivers have Failed Since 1:05:2016
This solution could not be downloaded
Most likely causes:
Your computer was unable to download the solution at this time. Check to make sure your computer is connected to the Internet, and then try to download the solution again later.
In Ark:Survival Evolved I'm getting 40fps. Blue screens And Black Screens, Error Warnings, Game Resetting after Video drivers failed and I have tried the 15.2,15.7 and currently on the Beta Drivers.
In DayZ standalone I'm getting 32fps. Also with Black screens and error warnings or Just the whole system freezing, and I have to do hard reboot. In Day of Defeat I'm getting 98 fps with a settings set to 200 fps in the Read only Reg. World of Warships I'm getting 46fps. and in the World of Tanks I'm getting 38 fps. In Rift (Glyph) I'm a low 28 fps.
When the computer goes to black for about 20 seconds afterwards you can hear a slight vibration or humm,
Current build:
Windows 7 (64) SP1
Antec 900 Full ATX case
ASUS M4A87T AM3 AMD 870 SATA 6Gb/s ATX AMD Motherboard
AMD Phenom II X4 960T Quad Core Processor (3.00 GHz, 8MB
Cache, Socket AM3, 95W
Scythe SCNJ-3100 120mm Ninja 3 Rev. B CPU Cooler
8 gig (4x2) 1600 Mushkin Red Line gaming memory quad channel
GDDR5 PCI Express 3.0 CrossFireX Support Double
Dissipation XXX OC Video Card
2x500 GB Cavier Green Hard drives
Windows 7 64 bit is one one {229 of 465 GB free}
Just the games are on the 2nd {338 of 465 GB free}
LG-26x DVD Burner Re-writer
LG DVD/CD rom
Power & Cooling Silencer MK-II 650 watt Silver Rated Power
Supply
Razer Anansi MMO Gaming Keyboard
Cooler Master Spawn Precision 3500 dpi Sensitivity on the fly mouse
Creative Labs Fata1ity Headset
Razor Mouse Pro Solutions Board
23" wide HD HP 1080i 2ms LCD Monitor w/ hdmi, DVi, VGA.
260mm top fan,120mm back fan, 2x 120mm front fans, 120mm side case fan Sits on top of Computer desk for Best Wind Flow.
Never O.C'd
FROM XFX Support
3/17/2016 11:35:32 PM By mark@xbez Type:2
Hello,
Thank you for contacting us about your issue. My name is Mark at XFX, I will be helping resolve this issue today.
Its possible the power supply is failing as well. Is the fan spinning in it?
Tutorial for proper driver installation.
1-Load windows with only your primary graphics card plugged in.
2-Disable any and ALL anti-virus/malware protection.
3-Download and Run the 15.11 (or latest) drivers from AMD.com (Omega drivers do not have Uninstall built in, you have to do it through add/remove, which is okay)
4-Choose to Uninstall/express (may not be available in newest version, download an older version) the existing drivers, and AMD folder
5-Restart the computer...
FROM XFX Support
Hello,
6-Disable any and ALL anti-virus/malware protection.
7-Run the 15.11 drivers from AMD.com
8-Choose to Install/Express the drivers
9-Restart. Confirm settings are working in windows.
10-Shutdown and add 2nd/3rd cards for Xfire.
11-Respond to this ticket if you have any further questions
** If you have nvidia drivers on your computer, you might need to run the Uninstall feature of Nvidias driver as well.
I followed the instructions on the 18th And that night I went into ARK and about 1/2 hour later I had a Blue Screen of Death, With the error message
The UE4 Shooter Game HAs Crashed and will close
LowLevelFatalError [File:F\UE4U\UnrealEngine\Source\Runtime\Core\Private\Serialization\Archive.cpp][Line: 163] FArchiv does not support FassetPtr serialization. Use FarchiveeUObject instead
KERNALBASE dll!UnknownFunction (0x0000007fefd33b3dd) + 0 bytes [UnknownFile:0)
And lots more info
So No I don't think the current Video Drivers Are working Correctly Do you?
