Xfx rx 460 2GB single fan 6 pin power connector
DerpBomb
Commendable
Jan 10, 2017
6
Hello. I am reciving an xfx rx 460 2gb single fan this week. It comes with a 4 to 6 pin power connector. It it possible to run without this? I have no idea where this connector thing would even go as I'm very new to pc gig and haven't messed around with one before. My current specs are :
Intel i3 4170
FSP Group 350W psu 30A on the 12v rail
Galaxy Gtx 750 1gb
Fractal design core 1500 case
Gigabyte GA-H81M-S2H Micro ATX LGA1150 Motherboard
Crucial 8GB (1 x 8GB) DDR3-1600 Memory
WD blue SATA HDD 1tb 7.2k rpm
Lite-On iHAS124-04 DVD/CD Writer
Windows 10 Pro x64 bit
Thanks in advance.
If it looks like this you are golden.
Will have 3 black, 3 yellow.
Tnx for the reply. I've been fiddling around with my wires and found a lead from my psu on a mixed yellow and black wire with a black connector at the end the looks like a 6 pin connector? Will this work? Tnx again for the reply the people on tomshardware are amazing.
Yes thank you Susquehannock! It looks exactly like that. So I just put the gpu in and plug up the connector right? I would select both answers of I could but I could only select one as the solved anser lol thanks again!!
