Xfx XXX 8800GTS Graphic card Temps
gokhan76
61
Hi Guys,
I am just wondering I just bought this system recently I build it up my self .
The GPU running on a full load probably around 70 degree but on a normal operation around 59 degree are these figures normal for a XFX graphic card by the way XXX series coming from factory overclocked to 550mhz 1.8ghz .
I need you guys opinions if it is too much high what can I do?
Thanks,
Ok,
What about 78 - 81 degrees when I play NFS most wanted
by the way the weather is hot too by all mean room wasnt cool.
But I am getting worried really is it going to be cook???
As some people have suggested, I put a PCI fan blower behind my 8800GTS and my idle-load temps are 48-65 tops (depends on the game, CoH puts the temp in 65). Also I run with the fan @ 100%. But I guess you are in the normal range of operation.
Your temps are fine.
If you want to lower temps... install Rivatuner and adjust fan speed.
http://www.softpedia.com/progDownload/RivaTuner--RC-Download-6867.html
When you open Rivatuner.
I have my adjusted at 100% all the time and when the system restarts it keeps the settings at 100% fan speed.
i third(or is it 4th) the previous statements. I have an 8800GTS that i OC'd to 650Mhz and 1.9Ghz, and my temps were in the 80-85C range with no artifacting.
as a side note, the stock drivers were still running the fan at 60% at this temp, I got riva tuner with the idea of getting it to run at 100%, but, for some reason, it will not set the fan to max speed, I had to use ntune to get the fan to max out, but it only allows up to 99% fan speed. after I got the fan to run faster, my temps dropped down to about 70C under load, and mid to high 50s when idle.
