Gigabyte P55-UD3R motherboard, i5-750, G.Skill Ram w/ heat spreaders, Xigmatek Balder cooler (basically their 1283 with a couple of minor changes).
This is the second machine I've built with this configuration. For the first one I had to settle for the 1284 cooler due to Newegg's inventory. The fan would not fit in its normal position because of the heat spreaders but I noticed that if I moved it up about 5mm or so then it would fit. I drilled 2 new holes in the fan for the rubber mounts so the fan could be raised and the mounts would still connect at the top of the fins. Testing the CPU at 3.9 GHz my temps got to 72. When I built that machine I noticed that there was plenty of room on the back side of the cooler to mount the fan there, and have it pull air through the cooler rather than pushing it through the cooler. So I'm wondering if anyone has tried this or if there is a reason why it would not work. It seems to me that it would work about the same either way.
I was working on another machine tonight, with the configuration listed above, but I haven't mounted the fan yet. The Balder cooler is very slightly thinner than the 1284, and if I shaved the bottom front edge of the fan I think I could probably put the fan in its prescribed location. But I can also easily mount it on the back of the cooler and let it suck air through the cooler.
