So i have been having problems running a lot of games after a major hardware change and a reformat of my hard drive.
I cant get any of my games running they all say XinPut1_3.dll is missing when I run them from there folders in admin mode, and in steam it said running first time setup but it never finishes. These are things I have tried.
I have reinstalled my directx files with the (13-12_win7_win8_64_dd_ccc_whq.exe) from windows I have tracked down my XinPut1_3.dll and I can find it but my computer claims it not there, even after re install. I have manually removed it so it wasn't there, and then reinstalled as mentioned above.
I have downloaded just the file and tried to replace it. I have cleared my reg files with CCleaner,I have used Ubuntu to try and get a manual connection between the game and the file bypassing windows Altogether and still no luck like my system refuses to run the file. and here is my system specs according to steam:
Processor Information:
Vendor: AuthenticAMD
CPU Family: 0x10
CPU Model: 0x4
CPU Stepping: 0x3
CPU Type: 0x0
Speed: 3210 Mhz
4 logical processors
4 physical processors
HyperThreading: Unsupported
FCMOV: Supported
SSE2: Supported
SSE3: Supported
SSSE3: Unsupported
SSE4a: Supported
SSE41: Unsupported
SSE42: Unsupported
Operating System Version:
Windows 7 (64 bit)
NTFS: Supported
Crypto Provider Codes: Supported 311 0x0 0x0 0x0
Video Card:
Driver: AMD Radeon HD 6570
DirectX Driver Name: aticfx32.dll
Driver Version: 13.251.0.0
DirectX Driver Version: 8.17.10.1247
Driver Date: 6 Dec 2013
Desktop Color Depth: 32 bits per pixel
Monitor Refresh Rate: 60 Hz
DirectX Card: AMD Radeon HD 6570
VendorID: 0x1002
DeviceID: 0x6759
Number of Monitors: 2
Number of Logical Video Cards: 2
No SLI or Crossfire Detected
Primary Display Resolution: 1920 x 1080
Desktop Resolution: 3520 x 1080
Primary Display Size: 26.65" x 15.00" (30.55" diag)
67.7cm x 38.1cm (77.6cm diag)
Primary VRAM: -2048 MB
Supported MSAA Modes: 2x 4x 8x
Sound card:
Audio device: Speakers (Realtek High Definiti
Memory:
RAM: 12202 Mb
Miscellaneous:
UI Language: English
Microphone: Not set
Media Type: DVD
Total Hard Disk Space Available: 476937 Mb
Largest Free Hard Disk Block: 247522 Mb
OS Install Date: Dec 31 1969
CPU Family: 0x10
CPU Model: 0x4
CPU Stepping: 0x3
CPU Type: 0x0
Speed: 3210 Mhz
FCMOV: Supported
SSE2: Supported
SSE3: Supported
SSSE3: Unsupported
SSE4a: Supported
SSE41: Unsupported
SSE42: Unsupported
Windows 7 (64 bit)
NTFS: Supported
Video Card:
VendorID: 0x1002
DeviceID: 0x6759
Sound card:
Memory:
RAM: 12202 Mb
Miscellaneous:
Microphone: Not set
Media Type: DVD
