XMP and cpu Core ghz Problem
Jul 23, 2018
9
Hello i have a problem to boot my pc, im using a i7 5960xat 1.285v in 4,6ghz until now I test but when i try to stress the cpu dont pass from the 1200ghz per core, activate the xmp to pass from 2133 mhz to 3200 mhz stop booting the pc my rams can keep 3200mhz my pc spec are:
I7 5969x
Mobo msi x99A gaming 9 ACK
Ram tridentz Z 3200mhz
Here is some photos about my OC’s
Im very new in this so every advice will help
what i can do to hit 4,5/4,6 and 3200 with rams?
thanks a lot!
https://imgur.com/XDNpImX
https://imgur.com/XsamYAg
https://imgur.com/tn9PsAX
https://imgur.com/hax8PqY
https://imgur.com/5DDkD7G
Immediately stop using MSI's XMP profiles! They are NOT the same as other brand's versions. Manually overclock both CPU & DRAM to get best results. I found this out on my MSI X99S XPower Gaming Titanium mobo w/ my 6850K OC'd to 4.3GHZ & my G.Skill 3000Mhz DRAM OC'd to 3400mhz. My vcore on my 6850K is @ 1.35V
Without seeing your settings in BIOS, I can't really say what it could be. Also, are you talking about DRAM of CPU core speed? It seems like you have both in your example.
If you are seeing 1200Mhz for your DRAM in CPU-Z, that is the actual clock speed. You will need to multiply by 2 to get what speed you are looking for. I.e: 3200Mhz DRAM could show as 1600Mhz in CPU-Z.
Make sure that you are disabling power saving C states & make sure to lock your cores @ full speed. You do not want any down clocking to happen when overclocking. Down clocking can lead to voltage dips or spikes that could BSOD, freeze, or crash what would be otherwise stable OCs.
Can we tLk trought skype or something and show what i have? Plus that im updating mobo bios, because have the first one, i desactivate all other things like EITS, i put in maximun performance but nothing
