Xmp issue with Asus Z97 pro
Paynegiver
26
As the title says I am having an issue with the XMP profiles, when I go into the bios and look I see X.M.P and it has a drop down menu but ONLY disabled is there... Also using passmark my memory shows 1333 only and it is rated at 1866 other tests appear to show it at 1866..... Any idea what the problem is? I also tried using the simple EZ-XMP switch on the motherboard and that seems to do nothing as well..
If it helps I am using this Ram: HyperX Fury Black Series http://www.amazon.com/dp/B00J8E8Y5C/ref=asc_df_B00J8E8Y5C3143554?smid=ATVPDKIKX0DER&tag=pg-391-01-20&linkCode=df0&creative=395097&creativeASIN=B00J8E8Y5C
I am installed into slots A2/B2 based on the recommendations of the manual. Any advice/tips would be appreciated.
I did this and XMP still shows Disabled only with no other options.
CPU-Z shows the following:
DRAM Freq: 932 mhz
Any ideas?
Don't do anything. Your RAM is operating at 1864MHz. How? Simple it is double data rate so any rate being shown in CPU-Z would be multiplied by 2 i.e 932 x 2 = 1864MHz,
Cheers
