Hello all,
I helped a friend build his very first gaming PC. I went for a MSI B550-A Pro since it has a nice VRM (for later upgrade to maybe 5950X), a 5600X and got a pair of two 16GB RAM sticks from Kingston, the Fury Renegade 3600MHz/CL16 version (with RGB).
The build seems to be working with the default speed of 2400MHz, but doesn't seem to work at all with either XMP profile.
I also tried manually setting to 3200MHz, even 3000MHz and lots of crashes, apps not starting even if they show up in task manager. Also I tried an Ubuntu install and that crashes as well. It seems to be somewhat stable at the default 2400MHz but he said even so got some random crashes.
I checked the compatibility list and this particular RAM does not show up sadly.
More exactly this is the code for the RAM: KF436C16RB1AK2/32
I was expecting this to not be an issue in these times but sure enough I should have made sure they're compatible.
Anyone using B550-A Pro with this RAM? Or any MSI B550 chipset with this particular ram and 5600X ?
What could I do to try and make it work?
Thanks.
Thanks.
