It's the first time I enable XMP, after saving and restarting it gives me the following error:
"AMIBIOS (C)2023 American Megatrends, Inc.
ASUS ROG MAXIMUS 2790 HERO ACPI BIOS Revision 1303
CPU: 13th Gen Intel(R) Core(TM) 19-13900KS
Speed: 5600MHZ
Total Memory: 32768MB (DDR5-4000)
USB Devices total: 1 Drive, 2 Keyboards, 1 Mouse, 6 Hubs
Detected Storages...
USB Device: KingstonDataTraveler 3.0
M.2_1: Samsung SSD 990 PRO 2TB
M.2_2: Samsung SSD 990 PRO 2TB
Please enter setup to recover BIOS setting.
After setting up RAID,
MD options must be set according to the interface type to avoid unknown issue
Press F1 to continue and take advantage of ASUS optimized performance!
If you wish to follow intel guidelines and apply its stock power limits, please disable the ASUS Multicore Enhancement (MCE) in the BIOS settings.
Next, you will enter the UEFI settings menu.
Press F1 to Run SETUP"
When I try to disable mce after a few seconds when I log in Windows goes into a blue screen and I have the bios updated thanks in advance everyone
Builds:
Rtx4090 rog strix
I9 13900KS
G.skill trident z5 7800Mhz 32gb 2x16
Asus rog Ryujin III 360
ASUS Rog Thor 1200w platinum
Ssd M2 Samsung 990pro 2tbx2
ASUS rog Maximus z790 Hero
Speed: 5600MHZ
Builds:
Rtx4090 rog strix
I9 13900KS
