R RaduV93 Commendable Mar 8, 2016 4 0 1,510 Mar 8, 2016 #1 Hello.I have the following problem.When I listen to music and oscilate betwen low and max volume,the volume slider stops working.The problem is resolven if I reinstall the driver. What could be causing this?
Solution Phillip Corcoran Mar 8, 2016 Oops - my bad. Asus of course. Try rolling driver back to previous version in Device Manager.
Phillip Corcoran Titan Moderator Sep 7, 2013 26,109 916 120,140 Mar 8, 2016 #2 No idea - - have you installed latest driver from Creative's website? Upvote 0 Downvote
R RaduV93 Commendable Mar 8, 2016 4 0 1,510 Mar 8, 2016 #3 Creative? It's an Asus card. And yes, I have the latest drivers. The problem appeared recently, it worked fine till now. Upvote 0 Downvote
Phillip Corcoran Titan Moderator Sep 7, 2013 26,109 916 120,140 Mar 8, 2016 Solution #4 Oops - my bad. Asus of course. Try rolling driver back to previous version in Device Manager. Upvote 0 Downvote Solution
R RaduV93 Commendable Mar 8, 2016 4 0 1,510 Mar 8, 2016 #5 Thanks for your reply.I found some Unix drivers and installed them.So far,so good. http://maxedtech.com/asus-xonar-unified-drivers/ Upvote 0 Downvote
