XP Another In-Place Upgrade, Repair, or some other trick? ..
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.abit (More info?)
Replaced Chaintech Chaintech 7NJS motherboard with Abit NF7-S.
Chaintech uses Promise PDC20376 SATA RAID controller, Abit uses
Silicon Image SIL-3112.
Did "in-place" upgrade as required, installed latest SATA drivers
during
boot, and added them during Windows XP Professional re-install.
Updated BIOS to the latest one - v.1.23 for motherboard version 2.0
Everything went smoothly, machine works, no performance issues.
However, Silicon Image SATA RAID driver in Device Manager appears in
"Other Devices" under the yellow question mark. All my attempts to
upgrade/reinstall/uninstall it have failed, or more precisely, Windows
never goes past its first splash screen after all such attempts - the
little thingie that runs from left to right before XP actually starts
to boot just stops and sits there. So it forces me to use "last good
menu".
I would suspect that there is a way to "clean up" the remnants of the
old drivers from the registry, but so far have not found a reference.
Any and all suggestions, ideas, and recommendations would be highly
appreciated.
Did you do a repair install? What is a "in-place" upgrade?
>during
>menu".
>appreciated.
Archived from groups: alt.comp.periphs.mainboard.abit,microsoft.public.windowsxp.hardware (More info?)
Here is some additional info. I got after digging through REGEDT32 in
two machines - one with driver installed improperly (after motherboard
upgrade) and the other one - identical machine with the correct
install.
Here is the first one
Key Name: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\PCI\VEN_1095&DEV_3112&SUBSYS_61121095&REV_02\4&3b1d9ab8&0&5840
Class Name: <NO CLASS>
Last Write Time: 5/14/2004 - 9:54 PM
Value 0
Type: REG_SZ
Data: RAID Controller
Value 1
Type: REG_SZ
Data: PCI bus 1, device 11, function 0
Value 2
Type: REG_DWORD
Data: 0x0
Value 3
Type: REG_DWORD
Data: 0x9
Value 4
Type: REG_MULTI_SZ
Data: PCI\VEN_1095&DEV_3112&SUBSYS_61121095&REV_02
PCI\VEN_1095&DEV_3112&CC_010400
Value 5
Type: REG_MULTI_SZ
Data: PCI\VEN_1095&DEV_3112&REV_02
PCI\VEN_1095&CC_010400
PCI\VEN_1095
PCI\CC_010400
PCI\CC_0104
Value 6
Type: REG_SZ
Data: 5&82f5f2c&8
Key Name: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\PCI\VEN_1095&DEV_3112&SUBSYS_61121095&REV_02\4&3b1d9ab8&0&5840\Device
Parameters
Last Write Time: 5/14/2004 - 9:27 PM
Parameters\Scsiport
Value 0
Type: REG_DWORD
Data: 0x1
Value 1
Type: REG_DWORD
Data: 0xb
Value 2
Type: REG_DWORD
Data: 0x5
Key Name: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\PCI\VEN_1095&DEV_3112&SUBSYS_61121095&REV_02\4&3b1d9ab8&0&5840\LogConf
Value 0
Type: REG_RESOURCE_REQUIREMENTS_LIST
Data:
Interface Type: PCI
Bus Number: 1
Slot Number: 11
List 0
Descriptor 0
Resource: Port
Option: 0x00000001
Disposition: Device Exclusive
Type: Port
Length: 0x8
Alignment: 0x1
Minimum Address: 0x00009000
Maximum Address: 0x00009007
Descriptor 1
Resource: Port
Option: 0x00000008
Type: Port
Length: 0x8
Alignment: 0x8
Minimum Address: 0x00000000
Maximum Address: 0xffffffff
Descriptor 2
Resource: Port
Option: 0x00000001
Type: Port
Length: 0x4
Alignment: 0x1
Minimum Address: 0x00009400
Maximum Address: 0x00009403
Descriptor 3
Resource: Port
Option: 0x00000008
Type: Port
Length: 0x4
Alignment: 0x4
Descriptor 4
Resource: Port
Option: 0x00000001
Type: Port
Length: 0x8
Alignment: 0x1
Minimum Address: 0x00009800
Maximum Address: 0x00009807
Descriptor 5
Resource: Port
Option: 0x00000008
Type: Port
Length: 0x8
Alignment: 0x8
Descriptor 6
Resource: Port
Option: 0x00000001
Type: Port
Length: 0x4
Alignment: 0x1
Minimum Address: 0x00009c00
Maximum Address: 0x00009c03
Descriptor 7
Resource: Port
Option: 0x00000008
Type: Port
Length: 0x4
Alignment: 0x4
Descriptor 8
Resource: Port
Option: 0x00000001
Type: Port
Length: 0x10
Alignment: 0x1
Minimum Address: 0x0000a000
Maximum Address: 0x0000a00f
Descriptor 9
Resource: Port
Option: 0x00000008
Type: Port
Length: 0x10
Alignment: 0x10
Descriptor 10
Resource: Memory
Option: 0x00000001
Type: Read / Write
Length: 0x200
Alignment: 0x1
Minimum Address: 0xe3000000
Maximum Address: 0xe30001ff
Descriptor 11
Resource: Memory
Option: 0x00000008
Type: Read / Write
Length: 0x200
Alignment: 0x200
Descriptor 12
Resource: Interrupt
Option: 0x00000000
Disposition: Shared
Type: Level Sensitive
Minimum Vector: 0x0
Maximum Vector: 0xff
Value 1
Type: REG_RESOURCE_LIST
Data:
Full Resource Descriptor 0
Interface Type: PCI
Bus Number: 1
Version: 1
Revision: 1
Partial Descriptor 0
Resource: Port
Disposition: Undetermined
Start: 0x00009000
Length: 0x8
Type: Port
Partial Descriptor 1
Resource: Port
Start: 0x00009400
Length: 0x4
Type: Port
Partial Descriptor 2
Resource: Port
Start: 0x00009800
Length: 0x8
Type: Port
Partial Descriptor 3
Resource: Port
Start: 0x00009c00
Length: 0x4
Type: Port
Partial Descriptor 4
Resource: Port
Start: 0x0000a000
Length: 0x10
Type: Port
Partial Descriptor 5
Resource: Memory
Start: 0xe3000000
Length: 0x200
Type: Read / Write
Partial Descriptor 6
Resource: Interrupt
Disposition: Shared
Vector: 11
Level: 11
Affinity: 0xffffffff
Key Name: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\PCI\VEN_1095&DEV_3112&SUBSYS_61121095&REV_02\4&3b1d9ab8&0&5840\Control
Value 0
Data:
Interface Type: PCI
Bus Number: 1
Version: 0
Revision: 0
Resource: Port
Start: 0x00009000
Length: 0x8
Type: Port
Resource: Port
Start: 0x00009400
Length: 0x4
Type: Port
Resource: Port
Start: 0x00009800
Length: 0x8
Type: Port
Resource: Port
Start: 0x00009c00
Length: 0x4
Type: Port
Resource: Port
Start: 0x0000a000
Length: 0x10
Type: Port
Resource: Memory
Start: 0xe3000000
Length: 0x200
Type: Read / Write
Resource: Interrupt
Disposition: Shared
Vector: 18
Level: 18
Affinity: 0x00000000
And here is the correct one
Last Write Time: 5/14/2004 - 8:17 PM
Value 0
Type: REG_SZ
Data: Silicon Image SiI 3112 SATARaid Controller
Value 1
Type: REG_SZ
Value 2
Type: REG_DWORD
Data: 0
Value 3
Type: REG_DWORD
Data: 0x9
Value 4
Type: REG_MULTI_SZ
Value 5
Type: REG_MULTI_SZ
PCI\VEN_1095
PCI\CC_010400
PCI\CC_0104
Value 6
Type: REG_SZ
Data: 5&82f5f2c&0
Value 7
Type: REG_SZ
Data: {4D36E97B-E325-11CE-BFC1-08002BE10318}
Value 8
Type: REG_SZ
Data: SCSIAdapter
Value 9
Type: REG_SZ
Data: Silicon Image
Value 10
Type: REG_DWORD
Data: 0
Value 11
Type: REG_SZ
Data: {4D36E97B-E325-11CE-BFC1-08002BE10318}\0000
Value 12
Type: REG_SZ
Data: SI3112r
Parameters
Last Write Time: 3/16/2004 - 5:24 PM
Parameters\Scsiport
Last Write Time: 8/18/2003 - 2:14 PM
Value 0
Type: REG_DWORD
Data: 0x1
Value 1
Type: REG_DWORD
Data: 0xb
Value 2
Type: REG_DWORD
Data: 0x5
Last Write Time: 10/22/2003 - 9:02 PM
Value 0
Data:
Interface Type: PCI
Bus Number: 1
Slot Number: 11
List 0
Descriptor 0
Resource: Port
Option: 0x00000001
Type: Port
Length: 0x8
Alignment: 0x1
Descriptor 1
Resource: Port
Option: 0x00000008
Type: Port
Length: 0x8
Alignment: 0x8
Descriptor 2
Resource: Port
Option: 0x00000001
Type: Port
Length: 0x4
Alignment: 0x1
Descriptor 3
Resource: Port
Option: 0x00000008
Type: Port
Length: 0x4
Alignment: 0x4
Descriptor 4
Resource: Port
Option: 0x00000001
Type: Port
Length: 0x8
Alignment: 0x1
Descriptor 5
Resource: Port
Option: 0x00000008
Type: Port
Length: 0x8
Alignment: 0x8
Descriptor 6
Resource: Port
Option: 0x00000001
Type: Port
Length: 0x4
Alignment: 0x1
Descriptor 7
Resource: Port
Option: 0x00000008
Type: Port
Length: 0x4
Alignment: 0x4
Descriptor 8
Resource: Port
Option: 0x00000001
Type: Port
Length: 0x10
Alignment: 0x1
Descriptor 9
Resource: Port
Option: 0x00000008
Type: Port
Length: 0x10
Alignment: 0x10
Descriptor 10
Resource: Memory
Option: 0x00000001
Type: Read / Write
Length: 0x200
Alignment: 0x1
Minimum Address: 0xdf000000
Maximum Address: 0xdf0001ff
Descriptor 11
Resource: Memory
Option: 0x00000008
Type: Read / Write
Length: 0x200
Alignment: 0x200
Descriptor 12
Resource: Interrupt
Option: 0x00000000
Disposition: Shared
Minimum Vector: 0
Value 1
Data:
Interface Type: PCI
Bus Number: 1
Version: 1
Revision: 1
Resource: Port
Start: 0x00009000
Length: 0x8
Type: Port
Resource: Port
Start: 0x00009400
Length: 0x4
Type: Port
Resource: Port
Start: 0x00009800
Length: 0x8
Type: Port
Resource: Port
Start: 0x00009c00
Length: 0x4
Type: Port
Resource: Port
Start: 0x0000a000
Length: 0x10
Type: Port
Resource: Memory
Start: 0xdf000000
Length: 0x200
Type: Read / Write
Resource: Interrupt
Disposition: Shared
Vector: 11
Level: 11
Value 0
Type: REG_SZ
Data: si3112r
Value 1
Data:
Interface Type: PCI
Bus Number: 1
Slot Number: 11
List 0
Descriptor 0
Resource: Port
Option: 0x00000001
Type: Port
Length: 0x8
Alignment: 0x1
Descriptor 1
Resource: Port
Option: 0x00000008
Type: Port
Length: 0x8
Alignment: 0x8
Descriptor 2
Resource: Port
Option: 0x00000001
Type: Port
Length: 0x4
Alignment: 0x1
Descriptor 3
Resource: Port
Option: 0x00000008
Type: Port
Length: 0x4
Alignment: 0x4
Descriptor 4
Resource: Port
Option: 0x00000001
Type: Port
Length: 0x8
Alignment: 0x1
Descriptor 5
Resource: Port
Option: 0x00000008
Type: Port
Length: 0x8
Alignment: 0x8
Descriptor 6
Resource: Port
Option: 0x00000001
Type: Port
Length: 0x4
Alignment: 0x1
Descriptor 7
Resource: Port
Option: 0x00000008
Type: Port
Length: 0x4
Alignment: 0x4
Descriptor 8
Resource: Port
Option: 0x00000001
Type: Port
Length: 0x10
Alignment: 0x1
Descriptor 9
Resource: Port
Option: 0x00000008
Type: Port
Length: 0x10
Alignment: 0x10
Descriptor 10
Resource: Memory
Option: 0x00000001
Type: Read / Write
Length: 0x200
Alignment: 0x1
Descriptor 11
Resource: Memory
Option: 0x00000008
Type: Read / Write
Length: 0x200
Alignment: 0x200
Descriptor 12
Resource: Interrupt
Option: 0x00000000
Disposition: Shared
Minimum Vector: 0
Value 2
Data:
Interface Type: PCI
Bus Number: 1
Version: 1
Revision: 1
Resource: Port
Start: 0x00009000
Length: 0x8
Type: Port
Resource: Port
Start: 0x00009400
Length: 0x4
Type: Port
Resource: Port
Start: 0x00009800
Length: 0x8
Type: Port
Resource: Port
Start: 0x00009c00
Length: 0x4
Type: Port
Resource: Port
Start: 0x0000a000
Length: 0x10
Type: Port
Resource: Memory
Start: 0xdf000000
Length: 0x200
Type: Read / Write
Resource: Interrupt
Disposition: Shared
Vector: 18
Level: 18
Any ideas would be highly appreciated.
v8625@hotmail.com (v8625) wrote in message news:<7c6d0c8e.0405131731.71c41b81@posting.google.com>...
> during
> menu".
> appreciated.
