XP problems please help
Tim0075
11
Since uninstalling ATI video/graphics software have a host of problems with windows xp
Drag and drop
Cut/paste
Cant access properties from right click menu
RPC service unavailable cant manually re start due to logon error 1069
Any ideas please help
Tim
wow... you might have damaged some system files... try running sfc /scannow from a command prompt
I ran the scan from command prompt it completed the scan but didnt give any info.
I cant reinstall windows xp3 because the cryptographic service isnt running, I cant copy, cut, move or send it to a cd.
1. Also according to https://support.microsoft.com/en-us/kb/929833
you might have to run sfc /scannow in safe mode.
at above site, they also mention how to get a more easily readable error log of the result:
"findstr /c:"[SR]" %windir%\Logs\CBS\CBS.log >"%userprofile%\Desktop\sfcdetails.txt""
2. found this from previous post http://www.tomshardware.com/answers/id-2997895/windows-click-properties-appearing.html
The issue that caused is was a registry from a VPN Software called Easy Hide Ip, deleted the remaining registries using autoruns by sysinsternals and the properties was restored!
I've tried manually restarting RPC service in safe mode getting the same error message. Cant start service because of logon error 1069.
With the cryptographic service I get error 1068
Going round in circles
