XP setup stuck on new build...need HELP Plz!
pistachio9
9
I made a new pc with the following parts...
Biostar GF8100 M2G+ (Onboard Geforce 8100 video)
AMD Athlon X2 7750
Kingston DDR2 800MHz 2GB RAM
Orange 300 W PSU (it has 20 PINS connector but works fine with my 24 PIN mobo)
Seagate (Model # ST330621A) 30GB PATA HDD (from my old PC)
DVD Rom
The problem is when i insert my Win XP cd inside the DVD ROM to install windows XP...it stucks right after SYSTEM RECOVERY CONSOLE options.when i hit enter to install XP...all i can see is a blue screen and on the lower side PLEASE WAIT...i waited for some time and after about 3 mins..it stuck on EXAMINING 2730 MBs on HDD. i waited a long time but no progress.....so anyone knows what is the problem....I have HDD as Primary master and DVD rom as Primary Slave on the only one IDE port on MOBO.....
