XP won't identify video card anymore !! Help !!
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Hi,
I've just installed XP SP2 on system with a GeForce 2 400MX AGP card
in it. On the install, XP correctly recognised the card and used it's
own drivers. Later, I tried the latest Nvidia drivers (77.77) and
found them to be a little sluggish in comparison. So, wanting to
return to the original XP ones, I uninstalled the Nvidia drivers via
control panel. On the reboot, XP detected the video card as a "Video
Controller (VGA Compatible)" and *not* as an "NVidia Geforce 2 MX 400"
(which it did on the install).
No matter what I do, I cannot get XP to recognise the card properly
again, nor install any drivers for it. I can however reinstall the
Nvidia ones and it is once again correctly seen as a Geforce 2 MX 400.
Remove them, and I'm back to "vga compatible" !!
I've tried 'sfc /scannow' to restore any critical files, but no joy.
If I tell it to automatically install drivers for it, it says it can't
find any, and likewise if I try manually ("I will choose the driver to
install") once I choose Display Adapters in the category list, it says
"no drivers are available" (or something to that effect).
It's driving me nuts !!!!
PLEASE !!! - Can someone help ? !! I'm presuming that the uninstall
of the Nvidia drivers took something with them that XP uses to
identify the card, but I don't know what !!
Cheers,
Kev.
G
Guest
Guest
You went wrong when you removed the Nvidia drivers using Add/Remove
programs. You should have just uninstalled the device in Device Manager. Try
System Restore or a manual system restore from the recovery console.
Brian P.
A+, Network+, MCP
<pcmangler@ntlworld.com> wrote in message
news:nsp9g11oc8rabhojdd9p2rs7d2pdirh9fk@4ax.com...
> Hi,
> Cheers,
> Kev.
G
Guest
Guest
On Thu, 18 Aug 2005 20:09:10 GMT, pcmangler@ntlworld.com wrote:
>Hi,
>in it.
Sorry.. I meant to say it was a complete install of XP (with SP2 built
in), rather than imply I was just applying SP2.
G
Guest
Guest
>Brian P.
>A+, Network+, MCP
Wouldn't XP just then have then redetected the card and used the
*still installed* Nvidia drivers ? Besides, everywhere I've looked
all say to use add / remove programs, and I've done this before on
other machines without any problems - it's always gone back to the
default XP drivers. I can't do a system restore now, I've put too
much software on since then and don't want to reinstall everything !
Surely the 'official' way to uninstall drivers is via add/remove
programs, and not via device manager ??
>> Hi,
>> Cheers,
>> Kev.
Brian
1,371
No actually the proper way is using the device manager as
95% of your drivers do not have a nice little installation package that will
appear in Add/Remove programs. A system restore should not wipe out your
programs and files, unless you use the restore files from the
%windir%\repair folder in the recovery console. Go to the Nvidia website and
search the archives for a previous release of the drivers you need.
Brian P.
A+, Network+, MCP
news:ne4bg1dorbp5anm1ggmaeo6mch64ncr20g@4ax.com...
Try
> >Brian P.
> >A+, Network+, MCP
> >> Hi,
> >> Cheers,
> >> Kev.
