Hey friends --
I salvaged some parts to make a new system. Since student loan payments prevent me from joining the A64 club right now, I had to do the best I could afford. It consists primarily of a Radeon 9600 Pro I got as a gift, a Barton 3200+ 200Mhz my friend gave me, and an VIA KT600 chipset with an MSI mobo. Many of you are aware of this already, but I left out major problem..
I have no cooling fan, so I used the one that was formerly on my overclocked Coppermine 933. Since Socket A and 370 have the same mounting brackets, I simply used the old fan until I can get a new one (which will likely be a Panaflo 92mm UHO mounted on a Swiftech MCX462-V).
The old one is a Thermaltake DragonOrbIII. It has a very heavy copper base so I figured I could run the XP3200+ a little slower with that cooler until I can get the new cooling solution. However, the system appears to have underclocked itself (this on the very first boot-up) to less than half the CPU speed (11 x 100 MHz = 1100)! What's more, at full load, the CPU temperature is 65 degrees. The system doesn't run stably past 1400 MHz right now.
I hope this is due to an inadequate HSF and nothing else. Does the 2nd fastest Barton core put out that much more heat than the 2nd fastest Coppermine? My concern is that there is something physically wrong with the CPU itself, as my buddy did a less than stellar job of packing and mailing it. I mean, 65 degrees at 1100 MHz? That seems bad, even with a silly Thermaltake cooler. Any thermodynamicists out there with some input?
<font color=blue> Be good to each other! </font color=blue>
