XSPC Cooling Kit Advice
Drummerdude1099
45
I am looking to do my first water cooling loop in a corsair 750d for a 4770k. I just want to do the CPU for now, but might do the GPU later. I am interested in this kit: http://www.frozencpu.com/products/21236/ex-wat-271/XSPC_Raystorm_750_EX360_Extreme_Universal_CPU_Water_Cooling_Kit_New_Rev_4_Pump_Included_w_Free_Dead-Water.html?tl=g59c683#blank
I understand that the XSPC Raystorm block is highly recommended, and the 750d can support a triple 140mm radiator, so this kit seems like a very good deal. To match my color scheme, I am looking at this cheap plate to put on the water block: http://www.ebay.com/itm/XSPC-Aluminum-Red-Edition-Mounting-Face-Plate-Intel-Raystorm-CPU-Block-/380775601363?pt=US_Water_Cooling&hash=item58a7fe94d3
I also would like to purchase some red tubing to match my colors, because I understand it will look a lot better than red liquid. I am new to the market, so I would like some suggestions on good quality red tubing. Please offer some advice on if you think this kit is a good product that will be compatible with my build. Would the pump be enough if I wanted to add a GPU block? Thanks for your time.
I used this stuff (white though) http://www.frozencpu.com/products/17889/ex-tub-1621/PrimoChill_PrimoFlex_Advanced_LRT_Tubing_716ID_x_58_OD_-_10ft_Retail_Pack_-_Bloodshed_Red_PFLEXA10-758-R_w_Free_Sys_Prep.html?tl=g30c99s809 when I redid my loop, I really liked working with it. With 1/2" barbs, I don't need (nor use) clamps. I might suggest getting two red 3mm led's to replace the blues that can be put into the block instead of (or in addition to) the red front plate
I really like the XSPC kits, I think it should serve you well, enjoy
