I own the XSPC D5 Phonton res/pump combo: https://www.amazon.com/gp/product/B01M23XVNL/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
I want to upgrade my water cooling system from soft to hard tubing as well change out my case to a Thermaltake Core x71. The case doesn't have preset mounts like I've been using with my Fractal case.
Can I take apart the combo and use the D5 pump in the basement of the case and mount the res up to next to the 420mm front rad?
If I can, please recommend some good tops for the pump and how I should go on with mounting them separately. ( I'm still a noob at this water cooling. )
