Hello. I need help on figuring out which XSPC Watercooling kit that will fit my Corsair 600t case. Here Is my build http://pcpartpicker.com/p/1Wb2h I plan on buying a custom XSPC Kit but I have no clue which one will fit the case.
Any 240mm XSPC would do you fine. Though you can't do a push/pull config so don't depend on that. The 600T is a really spacious mid-tower but not enough space for a push/pull config.
Id suggest the RayStorm 750 AX240 kit:http://www.xs-pc.com/watercooling-kits/raystorm-750-ax240-watercooling-kit
it has a water pump/resivor combo which can fit snug taking up two CD bays. Plus some nice LED lights and stuff.
Put the 240mm Radiator where the Top 200mm fan is. Put the two 120mm fans that come in the kit into the fan bay on the top of the case. That's the only config I can suggest.
