[SOLVED] XTU Problem
Actually i updated my Bios
That’s the problem. Newer BIOS’s are locking out manual voltage controls due to an Intel security fix. Your only hope is installing an older BIOS and then once installed resetting to defaults. This may or may not re-open the voltage controls.
I have an i7 6700 HQ and I have been using xtu for a time now (3months), suddenly xtu does not allow me to change undervolt and other settings!!! Pls help
image link = https://drive.google.com/open?id=1R8FMGFhW8NpXW5IJpcqcY0uNGFAk936R
Dear User,
Hi, I'm Draco and I will be assisting you today. The first thing I would advice you to do is to re-install Intel XTU Extreme Utility. If this fixes it, then your good to go. However, there is one more reason the core voltage and other options have been disabled.
The manufacturer of your core/gpu/pc has disabled the option to change anything. This might be so you don't mess up anything and corrupt or "brick" your system. Maybe contact Intel and see what they have to say about this.
