Hi all,
I just wrote a massive post, but it was just ramblings.
So far, I've decided on the following, but I am open to suggestions:
(EDIT -- SEE MY REPLY)
I don't really have a budget, as I have a bit of extra cash at the moment, but I don't want to go crazy - £700/$1100 or so would be pretty good, but can go more/will happily go less. This is just theoretical at the moment, anyways! I have never built anything other than intel, but if you have a better suggestion I'm up for listening.
Many thanks!
Many thanks!
