- CPU : Intel i5 7400 3.0 Ghz
- RAM : 16 GB
- Graphics card RTX 2060
- PSU : Corsair V650 (650 watts)
- Motherboard : Gigabyte h270m-d3h
- Fans : 3 external fans
- OS : Windows 10 / 64-bit
- Hard Drives : HDD 1 TB (Games) and SSD 120 GB (System files)
Do I need a better PSU?
- RAM : 16 GB
- RAM : 16 GB
Nothing actually.... I was just wondering if it might be bad on the long run.What problem or problems are occurring?
Noted! Thank you for your advice.no you probably don't - just check the 12V rail requirements of your GPU.
It's rated ate 180W TDP so it's less than half the rated wattage of your PSU before HDD's and the CPU so there's plenty
Yeah I do agree with the CPU bottleneck... do you have any suggestions as to what my CPU upgrade should be?650w is fine, but Corsair VS models are entry level and not designed for such a GPU.
PS, expect CPU bottleneck with that pairing
It will work. It just may be noisy and have a shorter lifespan than a better PSUNothing actually.... I was just wondering if it might be bad on the long run.
Really depends on budget.Yeah I do agree with the CPU bottleneck... do you have any suggestions as to what my CPU upgrade should be?
Thank you for the advice!Really depends on budget.
An I7 7700k is the best CPU for your motherboard, but only a quad core and overpriced.
That's good to know. Thank you so much!It will work. It just may be noisy and have a shorter lifespan than a better PSU
I don't really know what my budget is but usually I'll just buy anything that's appropriate for my pc.What is your budget?
Oh wow. My CPU is actually $400 and my mobo is $150.... so I guess I got scammed..PCPartPicker Part List
Type|Item|Price
CPU | AMD Ryzen 5 3600 3.6 GHz 6-Core Processor | $189.99 @ Amazon
Motherboard | MSI B450 TOMAHAWK MAX ATX AM4 Motherboard | $114.99 @ Amazon
| Prices include shipping, taxes, rebates, and discounts |
| Total | $304.98
| Generated by PCPartPicker 2019-12-24 21:15 EST-0500 |
If your ram is either single channel or under 3000mhz, upgrade that too
Damn.. I've got a lot more to study about computers.... Thank you so much I've learned a lot from your advise!!An I5 7400 sells new for $180
https://www.newegg.com/core-i5-7th-gen-intel-core-i5-7400/p/N82E16819117731
So yea, you got ripped off.
A 3600 performs like an I7 8700k
