You like to build pcs? Come and help me please :)
Kanekyyy
4
Hello I want to buy a new gaming pc in Lithuania so pcpartpicker doesint work for me. Everything in my country costs a bit more ofc.. so there is pages like 1a.lt or skytech.lt and others.So I want pc with intel proccesor,gpu NOT AMD(I just dont like it ) DDR4 16gb and other stuff.I dont know alot of about computers and how to build them so im asking for help. I can spend about 800 eur. IF u need more information write to me,ty!
Btw, Intel specialises in CPU; Intel GPUs are the crappiest of them all, the current common pair is Intel CPU + NVidia Geforce GPU / AMD CPU+ AMD Radeon GPU for gaming.
For a plug and play system,
https://pcpartpicker.com/list/62c4m8 If you can stretch your budget a little 😉 US$1000
Intel i7 6700
NVidia GTX 1070
kingston 8GB DDR4 2133
seagate 2TB 7200rpm HDD
Great enough for 1080p 60FPS on Ultra.
EDIT: Unless you want for some reason 16GB of RAM, then you may need to pay more or downgrade CPU. For gaming you just need a good CPU and a great GPU with ~8GB RAM
If you strike the lottery,
This is the best gaming setup you can get in 2017.
https://pcpartpicker.com/list/8CQG6X
Here is a build sourced from skytech.lt based on an i3-7100 and a GTX 1060-3GB. You should be able to play at high/ultra settings at 1080p. Component webpages first followed by PCPartPicker build with adjusted pricing.
http://www.skytech.lt/bx80677i37100-intel-core-i37100-dual-core-390ghz-3mb-lga1151-14nm-51w-vga-box-p-340589.html
http://www.skytech.lt/b250m-mortar-msi-b250m-mortar-lga1151-4xddr4-1xm2-6xsata3-p-340145.html
http://www.skytech.lt/cmk16gx4m2a2400c14r-ddr4-corsair-vengeance-lpx-red-16gb-2x8gb-2400mhz-cl14-120v-p-278605.html
http://www.skytech.lt/shfs37a120g-ssd-kingston-hyperx-fury-120gb-sata3-500500mbs-7mm-p-196658.html
http://www.skytech.lt/st1000dm010-internal-hdd-seagate-barracuda-1tb-sata3-7200rpm-64mb-p-323829.html
http://www.skytech.lt/dualrx4804g-asus-radeon-480-4gb-gddr5-256-bit-2xhdmi-dvi-2xdp-p-327836.html
http://www.skytech.lt/xdcdukase-deepcool-dukase-side-window-usb-usb-mic-spk-black-midletower-p-297870.html
http://www.skytech.lt/s12ii430-psu-seasonic-s12ii430-430w-plus-bronze-retail-p-71697.html
http://www.skytech.lt/tlwn881nd-tplink-tlwn881nd-300mbps-wireless-pci-express-network-adapter-p-114371.html
PCPartPicker part list: https://de.pcpartpicker.com/list/X7WHQV
Price breakdown by merchant: https://de.pcpartpicker.com/list/X7WHQV/by_merchant/
CPU: Intel Core i3-7100 3.9GHz Dual-Core Processor (€124.19)
Motherboard: MSI B250M MORTAR Micro ATX LGA1151 Motherboard (€92.19)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory (€114.99)
Storage: Kingston HyperX Fury 120GB 2.5" Solid State Drive (€63.39)
Storage: Seagate BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive (€51.29)
Video Card: Asus Radeon RX 480 4GB Dual Video Card (€217.29)
Case: Deepcool DUKASE ATX Mid Tower Case (€44.69)
Power Supply: SeaSonic S12II 430W 80+ Bronze Certified ATX Power Supply (€66.19)
Wireless Network Adapter: TP-Link TL-WN881ND PCI-Express x1 802.11b/g/n Wi-Fi Adapter (€13.79)
Total: €788.01
Generated by PCPartPicker 2017-03-09 18:26 CET+0100
Kanekyyy, i am just the same as you so pcpartpicker wont work (but if i set my location to australia, it might work). But i have simulated in the pcpartpicker and i will try to convert currencies. Anyways, i am from Indonesia.
Intel i7 6700
NVidia GTX 1070
