"Your PC ran into a problem and needs to restart"
socklosk
68
This is an intermittent problem, and never occurred with Windows 7. When I receive this error and reboot, my computer will usually not post. Repeatedly resetting the start button (about 50 to 100 times) will eventually allow the computer to boot, and all is well for a month or two.
The computer fans usually work when it happens, but I get no power to the black monitor screen. Removing the battery to reset the bios does nothing.
No memory errors, and I tried using a different set of memory from a different manufacturer. I also tried replacing the motherboard and PSU, Disconnecting the drives and USB devices does nothing, nor does moving the memory to a different channel.
My system is a Gigabyte H97 motherboard with i5 Intel CPU. The CPU is the only thing I have not tried replacing. Windows 10 was a clean install, and I do not have any errors using the sfc /scannow command. Virus and malware scans do not find anything.
If you ran into this problems I think it would be a Blue screen
Also there is a reason why does this happen written like a error code or a short description note that and redefine your search
When searching the Internet I found plenty of people who do experience a blue screen when rebooting from this type of an error, but with me, the computer will not post at all.
