Hello The Homie
You can try disabling Fast Startup in your OS and see if the issue is resolved. To do so:
> In the Cortana search bar, type
Power Options and click
Power Options from the displayed results list.
> From the left pane, click
Choose what the power button does.
> From the next window that appears, click
Change settings that are currently unavailable.
> From under the
Shutdown settings section, uncheck the
Turn on fast startup (recommended).
> Click
Save changes and restart the PC when done.
The issue should be resolved by now.
Cheers!!
