Hey!
Few months ago I bought an used pc.I put a windows 10 pro 64bit, before there was windows 8.1.
I used pc 3-4 moths.When I downloaded Windows 10 fall creators update and pc restarted I used it 1-3minutes and "Your pc ran into a problem, "Kernel security check failure".
After that I turned pc off and turned pc on again and I used the pc 7-9 days and there was Windows fall creators update 1803.
After I restarted the pc right away "your pc ran into a problem" and it was pfn list corrupt.I turned pc off and on again and everything worked normally 8-9 days.
Randomly again I had "your pc ran into a problem" and it was kernel security check failure again.I used pc few days and
When I started the pc I logged in to pc and monitor turned on and off and all the icons on the background as well.
I same windows 10 again and I used the pc 3-4 days and "Your pc ran into a problem" reference by pointer.I restarted the pc and used it 8-9 days again and randomly came new "your pc ran into a problem" memory management.
I used pc 8 days and today was "your pc ran into a problem" again system service exception.Does anyone know the problem and how to fix it?
My pc specs:
I5 4570
Msi z87 g41 pc mate
Crucial 1x8gb ddr3
Msi reference gtx 760 2gb
2tb Toshiba hard drive
Chieftec smart series 700w
My English is not the best.
My pc specs:
I5 4570
Msi z87 g41 pc mate
Crucial 1x8gb ddr3
