Youtube Audio/Video badly out of sync when system is under load.
Jul 5, 2018
24
Specs:
Gigabyte 1080ti Gaming OC
8700k @ 5GHz
32GB DDR4 3000MHz
If it means anything, this is only happening on my new system, my old system with worse specs, (i7 4790k @4.4GHz, 2x 970 SSC, and 24GB DDR3)
I don't know if this is a hardware issue, software issue, or overclocking/voltage issue. Please let me know what other information I can provide to solve this issue! The problem usually starts when I start gaming.
Random note.. What antivirus/firewall are you using? If you have Kaspersky or Zonealarm, I've had similar issues with them.
Network traffic loads up system/system interrupt usage in weird ways and that lowers actual network speed.
It is usually fine for hour to three hours after reboot and keeps escalating from there, at two to three weeks on (no sleep mode) speed would be at most like 3Mbit/sec and CPU usage at that time 80%
but still, likely not the issue but if you are using either one, try with windows default firewall, as far as I've noticed it or other software solutions have not had similar issues.
... Unfortunately and unwisely, no anti-virus
MERGED QUESTION
Question from grndy596 : "Audio out of sync during/after gaming."
There's a noticeable 1 second delay from the audio and video and it's making go crazy. It's been happening since I built the system and nobody has found a solution.
Asus z370-g mobo
i7 8700k @5GHz
32GB DDR4 3000MHz
NZXT Kraken X52 (240mm)
750W GQ PSU
Graphics and HD Audio drivers up to date. Audio has an occasional static/stutter as well.
LatencyMon Results
Code:
_________________________________________________________________________________________________________
CONCLUSION
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for  0:00:16  (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name:                                        MY-PC
OS version:                                           Windows 10 , 10.0, build: 17134 (x64)
Hardware:                                             ASUSTeK COMPUTER INC., ROG STRIX Z370-G GAMING (WI-FI AC)
CPU:                                                  GenuineIntel Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
Logical processors:                                   12
Processor groups:                                     1
RAM:                                                  32703 MB total
CPU SPEED
Reported CPU speed:                                   3696 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
WARNING: the CPU speed that was measured is only a fraction of the CPU speed reported. Your CPUs may be throttled back due to variable speed settings and thermal issues. It is suggested that you run a utility which reports your actual CPU frequency and temperature.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs):   2071.828562
Average measured interrupt to process latency (µs):   3.431079
Highest measured interrupt to DPC latency (µs):       2040.244120
Average measured interrupt to DPC latency (µs):       1.789729
 REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs):              36.138528
Driver with highest ISR routine execution time:       dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Highest reported total ISR routine time (%):          0.000456
Driver with highest ISR total time:                   dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in ISRs (%)                          0.000503
ISR count (execution time <250 µs):                   151
ISR count (execution time 250-500 µs):                0
ISR count (execution time 500-999 µs):                0
ISR count (execution time 1000-1999 µs):              0
ISR count (execution time 2000-3999 µs):              0
ISR count (execution time >=4000 µs):                 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs):              44.946429
Driver with highest DPC routine execution time:       Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Highest reported total DPC routine time (%):          0.000228
Driver with highest DPC total execution time:         Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Total time spent in DPCs (%)                          0.000678
DPC count (execution time <250 µs):                   372
DPC count (execution time 250-500 µs):                0
DPC count (execution time 500-999 µs):                0
DPC count (execution time 1000-1999 µs):              0
DPC count (execution time 2000-3999 µs):              0
DPC count (execution time >=4000 µs):                 0
 REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count:                 msmpeng.exe
Total number of hard pagefaults                       1
Hard pagefault count of hardest hit process:          1
Number of processes hit:                              1
 PER CPU DATA
CPU 0 Interrupt cycle time (s):                       0.90780
CPU 0 ISR highest execution time (µs):                36.138528
CPU 0 ISR total execution time (s):                   0.000939
CPU 0 ISR count:                                      110
CPU 0 DPC highest execution time (µs):                44.946429
CPU 0 DPC total execution time (s):                   0.001160
CPU 0 DPC count:                                      324
CPU 1 Interrupt cycle time (s):                       0.155929
CPU 1 ISR highest execution time (µs):                0.0
CPU 1 ISR total execution time (s):                   0.0
CPU 1 ISR count:                                      0
CPU 1 DPC highest execution time (µs):                1.449675
CPU 1 DPC total execution time (s):                   0.000003
CPU 1 DPC count:                                      2
CPU 2 Interrupt cycle time (s):                       0.064956
CPU 2 ISR highest execution time (µs):                0.0
CPU 2 ISR total execution time (s):                   0.0
CPU 2 ISR count:                                      0
CPU 2 DPC highest execution time (µs):                4.541126
CPU 2 DPC total execution time (s):                   0.000010
CPU 2 DPC count:                                      4
CPU 3 Interrupt cycle time (s):                       0.058631
CPU 3 ISR highest execution time (µs):                0.0
CPU 3 ISR total execution time (s):                   0.0
CPU 3 ISR count:                                      0
CPU 3 DPC highest execution time (µs):                1.087121
CPU 3 DPC total execution time (s):                   0.000002
CPU 3 DPC count:                                      2
CPU 4 Interrupt cycle time (s):                       0.054930
CPU 4 ISR highest execution time (µs):                0.0
CPU 4 ISR total execution time (s):                   0.0
CPU 4 ISR count:                                      0
CPU 4 DPC highest execution time (µs):                1.021104
CPU 4 DPC total execution time (s):                   0.000002
CPU 4 DPC count:                                      2
CPU 5 Interrupt cycle time (s):                       0.051254
CPU 5 ISR highest execution time (µs):                0.0
CPU 5 ISR total execution time (s):                   0.0
CPU 5 ISR count:                                      0
CPU 5 DPC highest execution time (µs):                3.390152
CPU 5 DPC total execution time (s):                   0.000004
CPU 5 DPC count:                                      2
CPU 6 Interrupt cycle time (s):                       0.060550
CPU 6 ISR highest execution time (µs):                0.0
CPU 6 ISR total execution time (s):                   0.0
CPU 6 ISR count:                                      0
CPU 6 DPC highest execution time (µs):                3.488095
CPU 6 DPC total execution time (s):                   0.000006
CPU 6 DPC count:                                      3
CPU 7 Interrupt cycle time (s):                       0.051853
CPU 7 ISR highest execution time (µs):                0.0
CPU 7 ISR total execution time (s):                   0.0
CPU 7 ISR count:                                      0
CPU 7 DPC highest execution time (µs):                12.635281
CPU 7 DPC total execution time (s):                   0.000021
CPU 7 DPC count:                                      6
CPU 8 Interrupt cycle time (s):                       0.061744
CPU 8 ISR highest execution time (µs):                3.225649
CPU 8 ISR total execution time (s):                   0.000003
CPU 8 ISR count:                                      1
CPU 8 DPC highest execution time (µs):                37.251082
CPU 8 DPC total execution time (s):                   0.000064
CPU 8 DPC count:                                      16
CPU 9 Interrupt cycle time (s):                       0.061977
CPU 9 ISR highest execution time (µs):                1.345238
CPU 9 ISR total execution time (s):                   0.000023
CPU 9 ISR count:                                      40
CPU 9 DPC highest execution time (µs):                0.984307
CPU 9 DPC total execution time (s):                   0.000002
CPU 9 DPC count:                                      2
CPU 10 Interrupt cycle time (s):                       0.059127
CPU 10 ISR highest execution time (µs):                0.0
CPU 10 ISR total execution time (s):                   0.0
CPU 10 ISR count:                                      0
CPU 10 DPC highest execution time (µs):                5.653680
CPU 10 DPC total execution time (s):                   0.000010
CPU 10 DPC count:                                      4
CPU 11 Interrupt cycle time (s):                       0.051299
CPU 11 ISR highest execution time (µs):                0.0
CPU 11 ISR total execution time (s):                   0.0
CPU 11 ISR count:                                      0
CPU 11 DPC highest execution time (µs):                8.665043
CPU 11 DPC total execution time (s):                   0.000017
CPU 11 DPC count:                                      5
