Yumi/Multiboot won't load.
atCaleb
Commendable
Apr 6, 2016
5
Hi,
I'm currently trying to install Ubuntu along side my Windows 10 machine. I'm using Yumi. I currently have a 15BG (Fat32) Partition that has Ubuntu ready and loaded up. The only problem is, when I go to restart the PC It doesn't boot into the Yumi GUI, nor does show my partition via my BIOS.
Summary - I have Ubuntu on Fat32 Partition loaded with Yumi. When I start up, no option allows me to choose Ubuntu, and can't see partition via BIOS.
EDIT: I've checked by bcdedit /enum and it shows Windows Boot Manager & Windows Boot Loader.
Hello,
An Important point to note, as Win-10 Anniversary gets pushed out over the next weeks, there are reports that the update interferes or breaks the dual boot setup with Linux or Ubuntu.
Aside from that, here is a good link that takes you step by step in setting up a Linux distro with GRUB, as a dual boot system, with Windows 10 being installed first.
http://www.tecmint.com/install-ubuntu-16-04-alongside-with-windows-10-or-8-in-dual-boot/
Hello,
Ah yes, I've heard the rumors via Reddit regarding the situation of corruption of duel boots. I've also heard It'll delete data on other drives without asking. Very unfortunate. I'll check out the link you sent me, thanks.
