Hello everybody,
I'm building a new Pc config with the mentioned ASUS z170-K mobo. I'd like to reach 32Gb RAM with the highest possible clock.
I've checked the official mobo specifications here:
http://dlcdnet.asus.com/pub/ASUS/mb/LGA1151/Z170-K/Z170-K_Memory_report.pdf?_ga=1.244082883.754179054.1463655486
1.
My problem that it's just generally confusing to me. There are rows like this:
CORSAIR CMD128GX4M8A2666C15 128GB (16GB*8 )
But... this motherboard doesn't support 128GB as I know but and it has only 4 dimms! How could we put 8 into it then? :/
Please help me out with an explanation.
2.
I'd like to install only 16GB at this moment using only one RAM pair. (2x(GB) Because I'm not sure that I will use more than this... but I'm sure that after 4-5 years I will increase this number. (I will use the Pc as a vsti audio and graphic workstation)
But in this list I can't see any possible way to install RAM like this on a higher clock frequency than the normal 2133. Is it really impossible? I've checked other z170 mobos and the they aren't significantly better in this question.
I'm just really not sure because this document is kinda confusing to me and at some parts there are even duplicated ram lines with different specs... I'm not sure if this document is just wrong at some lines or my understending is bad.
Thanks for any replies!
1.
2.
