I asked ASRock how much power each fan header can put out, this is what they said.
motherboard support 12 volts dc , 1 amp maximum , 12 watts per pin out header.
I have 6 case fans at all and they are Bitfenix Spectre pro 140mm fans. 2 in the front, 2 up top, 1 in the back, and a be quiet cooler on the back.
Each fan except the CPU cooler draws 12v each, I dont know how many I could put in if each header supports 12w. The CPU cooler is a be quiet cooler. My power supply is a evga 600W also.
