[SOLVED] Z370M DS3H-CF will be okay with ryzen 5 5600x
roid555
26
Hi,
I planing on upgrade my i5 8400 to ryzen 5 5600x,
currently I have this MB Gigabyte Z370M DS3H-CF
Do I need to upgrade the MB too? not sure if it will work
And if it won't work, can you suggest me a MB to buy with it?
I have 1050ti and planing to but the 3070 when it will be available, so probably not in the near future xd
and RAM g.skill 3600 2x8GB 14 LC
oh thank you!
I will check about this MB, but I guess it can works with any GPU right?
if possiable can I ask for more MB options from you and others here 😀
Here is a list of processors supported on your motherboard:
https://www.gigabyte.com/Motherboard/Z370M-DS3H-rev-10/support#support-cpu
The strongest would be a i9-9900K. about a $400 processor.
More likely your games are graphics limited if you play fast action games.
If you are cpu limited, and on a budget, that same $400 will buy you a i5-11400 and a lga1200 motherboard with change left over.
Here is a review:
Look at the 10 game performance average, the 11400 is not far behind the 5600x
Newegg shuffle offers 3070 graphics cards but with an added product that you may or may not want. Often with am4 motherboards.
