[SOLVED] Z390 Aorus Pro ARGB headers.
Nivz0r
85
7
545
Hey,
Got this z390 aorus pro mobo for 3 months and it works perfectly fine.
Yesterday i tried to plug my ARGB 120 ANTEC FANS which i tried before and are working properly.
Plugged them into the argb header on the motherboard and nothing.
I Also tried led strip to the ARGB and another LED strip to RGB header but it doesn't work.
It doesn't show any light as if the header is not working. Seems weird since the mobo is new.
Any ideas?
Also on the aorus website it shows the z390 aorus pro has LEDs on the ram also but it doesn't show.
Sorry I didn't know i needed to download the RGB Fusion software first.
It works fine now.
This is the first mobo that i plugged LED strip and it only worked after downloading the software.
