A adamek9605 Prominent Jun 8, 2017 5 0 510 Jun 11, 2017 #1 Hi! I have a asrock z77 extreme4 mobo and i cant find G.Skill Ares F3-2400C11-8GAB on the supported ram list. will it work with it? Is it safe to put it in?
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,872 159,590 Jun 11, 2017 #2 What CPU is it a K VARIETY. Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,872 159,590 Jun 11, 2017 #4 I would recommend anything beyond 2133. I ran 1866 Snipers. ARES are very good modules. Upvote 0 Downvote
A adamek9605 Prominent Jun 8, 2017 5 0 510 Jun 11, 2017 #5 Im not planning to run it on 2400mhz. My only question is will it work? Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,872 159,590 Jun 11, 2017 Solution #6 Yes it should work , but it may or may not run at FULL spec. Upvote 0 Downvote Solution
A adamek9605 Prominent Jun 8, 2017 5 0 510 Jun 11, 2017 #7 Thanks for the fast answer Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,872 159,590 Jun 11, 2017 #8 Absolutely , glad to assist. Upvote 0 Downvote
