Z77 Sabertooth Boot Device Red Led - Not Posting
Aug 15, 2018
4
I hadn't planned on using my computer again and had disposed of my HDD. Well, after 4 months I'm trying to get it working again.
Right now I don't have a boot device connected, I'm just trying to get to bios, but all I'm getting is a black screen.
I've tried multiple cables and multiple monitors with no luck. I've pressed the memok button and the bios reset button with no luck.
I believe my cpu is an i7 3770k, but it's been so long I can't remember, but I didn't have this problem any other time when setting it up
I tried connecting my SSD. No luck still getting the boot device led.
I cant imagine it would require a boot device to get to the bios though.
Me neither. It was just a shot.
Being it's been sitting for a while. I probably would reseat everything.
I have had experiences where....the air where I work isn't exactly the cleanest.....and if electronics sit for a while.....they get a coating on them and I've had problems with connections....and reseating everything has helped quite a few times.
I've actually already done this. I'm at a loss as to what else the problem might be.
Well....it could be a PSU issue (the voltage(s) aren't correct). I might check them with a voltmeter.
If they are correct....I would focus on the motherboard/processor next....unless you have a graphics card. Do you? If so, the issue may lie in the graphics card. and do you have integrated graphics?
I have a GPU. I just can't imagine that after it working for over a year that it would have an issue like that just from changing the hdd.
