J jtomczyk Reputable Mar 6, 2014 2 0 4,520 Mar 6, 2014 #1 Just built my system, z87 Pro mobo i7 4770K ; 16mg, GTX 550Ti, 600W PS, I tried without GPU Card into back of board and I still get no red on monitor, tried this with 2 different monitors; VGA connect to board works fine. Help
Ironsounds Champion Jul 31, 2011 10,402 4 56,960 Mar 6, 2014 #2 Hello... are you USING a DVI cable and DVI connector ON your monitor? no adaptors? Upvote 0 Downvote
J jtomczyk Reputable Mar 6, 2014 2 0 4,520 Mar 6, 2014 Solution #3 Pin bent on one DVi connection, straightened, works fine now. Upvote 0 Downvote Solution
Tradesman1 Legenda in Aeternum Jun 5, 2013 67,881 40 126,960 Mar 7, 2014 #4 Might have a bent pin in the DVI connector.....(just kidding), glad you found the problem Upvote 0 Downvote
