Z87 with Haswell compatibility issue?
If you are out of luck with BIOS, then no it's not that simple of a fix. It requires a CPU which the MoBo can recognize.
i5 4670k and i5 4690k are almost identical in real-world performance, the newer one *may* OC a bit better, but that depends a lot on chip lottery. If you can get 4670k for same price, go for it, it'll eliminate any potential risks of BIOS update and will perform as well as the 4690k.
If the MoBo you bought was manufactured after April '14, it'll come updated to support 4690k. Considering you purchased it sometime earlier, and the shop (or E-shop) didn't hand you like the most ancient piece available, your MoBo will support it. If in the unforunate case it isn't updated, for whatever reason, you'd then need to put a CPU which it supports w/o update and apply an update, or simply RMA it for an updated board.
maxalge
Champion
Ambassador
I like your build, drop that cx corsair though.
Get a xfx. non cx corsair, seasonic, or evga psu.
In order to use a haswell refresh you need bios 7845v1A.
More than likely you will need to update the bios yes.
pugchampion
29
hmm well i got it off ebay so im not sure how new it is.
is it worth just getting an i5-4670k or is this a simple fix worth doing and if i did get an 4670k how much of a performance decrease would i have?
pugchampion
29
ok ill change that and what exactly makes the Corsair Cx ones worse then the others?
pugchampion
29
ok sounds good then thx for the help man yeah ill probably just go with the 4670k too save the chance of headaches haha
