Z97 Asus Pro Wifi will not reset cmos.
AlbusDlxxx
5
Hi.
I have a problem. I tried some new timings on my ram and the PC now are stuck in a boot cycle until I reset PSU and the PC tells me over clocking failed. But F1 leads to god d*mn windows instead of bios. So now I have instability and 1333 ram speed instead of 1866. I have removed the battery. I have tried bios flashback button on mobo. I have switched sockets on the ram (Kingston 1866 fury dimms) Do I dare do a manual bios flashback to an older efi fom asus website? Or could that brick my mobo? Because Im not in a spot where I could get another one right away. =)
1| When posting a thread of troubleshooting nature, it's customary to include your full system's specs inclusive of your OS. Please list them as:
CPU:
Motherbaord:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
2| Have you made sure you're on the latest BIOS revision? IF so which version are you on?
3| After removing the CMOS battery, did you replace it after 15 minutes and then tried powering up?
4| If you must flash your BIOS to an earlier revision please follow the steps outlined in your manual+that you're working with a pen drive that is formatted in the FAT32 filetype beofre dropping the BIOS file onto it's root directory.
CPU:
Motherbaord:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Thx for your answers.
Unplugging boot drive could be the thing that solves it. Will try it out later on.
I am on the latest bios, revision 2702.
I thought the battery only needed to be out like 30 seconds to reset cmos? 15 min the new standard? If so I must try that out again as well.
As for my full specs:
CPU: i7 4790k
Motherbaord: Asus Z97-PRO(Wi-Fi ac)
Ram: Kingston Fury 1866 2x8gb
SSD/HDD: Samsung 850 Evo (boot drive) + Seagate 3tb storage
GPU: GTX 970 Gigabyte Windforce 3
PSU:Corsair 850w
Chassis: Corsair Air 540
OS: Win 10 x64
