R ryder_22 Distinguished Jul 7, 2006 93 0 18,630 Jul 10, 2006 #1 How do I disable the LED feature? Is the 9500XT the same version w/o the LED? Thanks
The_Prophecy Splendid Moderator May 16, 2006 6,674 26 27,340 Jul 10, 2006 #2 i'm pretty sure you can't turn the LED's off.....
badge Illustrious Jun 17, 2006 13,722 0 41,460 Jul 10, 2006 #3 How do I disable the LED feature? Thanks Click to expand... LOL. The leds are built into the fan You might take the fan apart and break off the leds. It's a feature that is disabled only by breaking it or putting in a new fan without the disable feature.
capnbfg Distinguished Jun 10, 2006 146 0 18,680 Jul 10, 2006 #4 Is the 9500XT the same version w/o the LED? Click to expand... Do you have an AMD or Intel system? If it's an Intel LGA775 rig, then: Zalman CNPS9500AT (Non-LED Edition) If you have any other socket then this will not be compatible.
