ZALMAN CNPS9500A-LED Cooler not compatible with AM3+?
ClubSpade12
241
It says on their website that it's compatible, but the instructions have minimal helpfulness and there are no videos or threads about this cooler anywhere that I could find. I have no idea how the heck to get this thing hooked up and I need help.
You don't use any screw's for am3 socket at all.
Theres a single curved bar in the box approx 3.5 i chea long with 2 square blocks & cutouts each end & a hole inthe middle
The middle hole latches onto the heatsink plate below the main part of the cooler .
The squate cutouts on the ends latch onto your black plastic cpu brackets that came on the board already fixed
There aren't plastic brackets on the motherboard? Those brackets have always come with the CPU for me, you screw them in. This CPU Cooler didn't come with one, looks like. But it still says it's compatible? I'm confused as to why I can't get it in, I can't really explain why that doesn't fix my problem, but it doesn't.
Alright, I guess in a way it did sort of help, but what I did was take the bracket from another cooler and used extra screws from ANOTHER cooler and managed to get it on. This CPU Cooler does not come with said brackets, and that's the real issue here. Thanks for all the help!
