Zalman Z11: Cleaning and Accessibility?
beehivemind
Commendable
Nov 13, 2016
14
Hey there,
amateur gamer here. I've noticed an increase in GPU temperatures during the past few months and i'm assuming the CPU's temp rise is a direct result of that. Afaik none of the temperatures are critical yet (GPU 65 to the occasional 84°C/CPU 30-45°C after a day of shameless nonstop gaming), but i'd like to do some maintenance before the whole thing sets itself on fire.
Unfortunately the Zalman Z11 chassis is an impractical mess to work with imo. (The GPU needs to be taken care of as well, but there's enough tutorials on that online.)
There's a lot of residue dust built up on the mesh protecting the front fan, but i'm finding it extremely hard to gain any access to it. A quick google search told me to remove a thing here or there and tug on it with as much gentle force as possible - but it's likely some parts will still break.
I'm probably gonna sound like a complete tool here, but i'm very small. Tiny. This is not a case i can safely handle and tug on with an arm width this small, and i'd rather not risk lasting damage either.
So i'm wondering how to get this fan/mesh cleaned without taking of the chassis' front bit.
- The most common search result would prolly suggest canned air, which id have to apply from the inside of the chassis in order to get the dust out rather than blowing it directly onto the GPU or PSU. Considering the sizes of these cans i doubt this is possible without dripping icy liquid everywhere while trying to position it, and i'm suspicious about dust spreading all over the inside of the front panel due to unfortunate air flow rather than anything else, too.
- Some search results suggested actual household vacuum cleaners for PC maintenance. Since i wouldn't stick it inside the chassis, but rather hold it in front of said mesh it wouldn't really touch anything of value. And sucking in that residue seems more likely to ensure it's gone rather than getting spread all over the place. On the other hand lotsa people also pointed out this might be an electrical discharge issue, and i can't tell if my itsy bitsy antistatic bracelet would help much against the power behind a vacuum cleaner.
- I've tried scrubbing it off gently and carefully with a Q-Tip through the front lamellas. Which did absolutely nothing, other than to clog it even more. This ain't happy fun dust, it's heavy, the particles are tiny and it's sticking to everything like glue with separation anxiety.
tl;dr: I just wanna clean that dang mesh (and fan). Is there any way to do this without removing the front panel? If not, is there any way to remove it safely that doesn't include vague amounts of brute force and sheer luck? [strike]And is soaking a GPU in high quality Isopropyl/dousing it off with water and letting it dry for at least (!) a week in a dust-minimal environment gonna get me a Darwin award or is this actually reasonable?[/strike]
Just pull the front I/O off the case to clean it.
Here's an image of the underside of the Z11,
See the small gap under front I/O? Just put your fingers through it and pull.
Under the spoiler is a small tutorial i created to show on how to do it. While i used my Gigabyte GZ-G2 Plus case to show it, the method is same with your case as well.
1. There should be a gap under your PC where to put your fingers in (top left image).
2. Put your fingers into that gap and pull (top right image). It may take quite a lot of muscle power to pull the front I/O off. It's easier to do when case stands upright but for better view, i set my case on it's side.
3. After...
1| No!
2| You should stop overthinking it and remove the front panel to deal with all the dust and debris.
3| Like the reviews suggest, tugging it will reveal the front innards.
4| The rest of the components can be cleaned after you deal with the front fascia since it'll draw in more air and, mechanically, more dust.
Yeeeah, you're probs right. Having extremely small hands (kids glove sizes) and short arms just makes the handling of a semi-large item with fragile components more of a risky thing than you'd usually expect, cause your grasp on it just ain't that secure. At all. Not gonna risk toppling over an entire PC if it's avoidable, so if there's any trick to it i'd wanna know beforehand.
Anyways, seems like i'll def have to take it off, maybe i'll ask a bigger buddy for help. Thanks a lot for your quick reply! [strike]And no, i'm not gonna dump an entire GPU into liquid of any kind. No worries.[/strike]
3. After pulling, the front I/O pops loose (bottom left image).
4. Don't pull too far since there are cables going to the front I/O. While this method seems rude, it's the most common way to remove case's front I/O panel, so you can mount/clean front fans (bottom right image).
