A Andrei_34 Commendable Nov 4, 2016 2 0 1,510 Nov 4, 2016 #1 What type of connector does the rear fan have,i have read that is a 4 pin molex but i am not sure i want a confirmation,can i connect that directly to the psu?
Solution R R Robert319 Nov 4, 2016 Andrei_34 : What type of connector does the rear fan have,i have read that is a 4 pin molex,can i connect that directly to the psu? here mostly it is 3 or 4 pin conector. On older systems there is 2 pin conector or 4 pin molex yes you can conect fan directly to power supply
R Robert319 Reputable Nov 4, 2016 47 0 4,540 Nov 4, 2016 Solution #2 Andrei_34 : What type of connector does the rear fan have,i have read that is a 4 pin molex,can i connect that directly to the psu? here mostly it is 3 or 4 pin conector. On older systems there is 2 pin conector or 4 pin molex yes you can conect fan directly to power supply Upvote 0 Downvote Solution
