I decided to check here since I am going to change out my front case fan. I know how to install and all that, but how would I be able to remove the front cover? Are there screws that I need to remove to get to the fan or is it basically "tool-less" that you can just remove without screws and all that.
Here is my case if you are interested:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811235045&ignorebbr=1
And if you are curious, here is the fan I am looking at:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835553010
Hopefully I make sense. XD
Thanks in advance.
Thanks in advance.
