Zalman Z3 Plus how to remove front panel
rascalov
67
Hello community. I want to remove the front panel from Zalman Z3 Plus to clean out the dust.
How can I remove the front panel? Does it matter if I have all the other components installed when I do this operation?
Thanks in advance.
Pasted from elsewhere: "the top comes off upwards by releasing the tags along the under side of the top"
There's no need to remove any internal components when blowing all the accumulated dust out from inside.
Just take care with the fans that you don't have them hitting supersonic speeds much faster than they were designed for when you use the blower on them - - quick, short blasts is the way to do deal with them.
Reactions: rascalov
